dual XGS1010-12 10gig passthrough
Devincean
Devincean Posts: 1 image  Freshman Member
edited August 2022 in Switch
So i have dual of these XGS1010-12 switches both with two 10gig sfp+ ports. On one switch I'm using both SFP+ 10g ports. One to connect to my router and the second port to pass through to my second XGS1010-12 switches 10g sfp port. I seem to have a lot of issues were this is disconnecting the second XGS1010-12 when i put close to 10gig bandwidth use over it. I'm unsure if this is not supported on this switch. It said it could be use as core backbone which is what i was trying to use them for having one pass the 10gig onto the second switch. Could this be a issue with the SFP+ i have they are all QSFPTEK 10GBASE-T SFP+ RJ45 Transceiver, SFP to rj45 Copper Module. I have used a tester to verify sfp and cable to be able to pass and receive 10g without issue. This leads me to wonder if the switches have a issue.
  • Zyxel_Jason
    Zyxel_Jason Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Devincean,
    Welcome to Zyxel community!
    From your description, I assume your network topology is like:
    Router---[XGS1010-12]---[XGS1010-12]
    May you share more details about your testing like how you test and more specific about the symptom(disconnecting)?
    I am not sure if you saw the packet loss or actually Switch port link down when issue happened.
    Please also note that you may use SFP+ to RJ45 transceiver, but we don't guarantee it will work without any problem when connecting on our Switch.
    Therefore, I would also recommend you trying Zyxel 10G transceiver and fiber cable on our Switch.
    Hope it helps.
    Jason
