SBG 5500 L2TP over IPSEC
i setup the VPN on my windows server, forward the ports 1701 1723 and 500
but the server says that VPN connection cannot be completed because of probably missing GRE
i have not found any GRE settings on the firewall or port forwarding rules. on old Zywall 5 firewall it used to be a special service called PPTP_TUNNEL(GRE:0) but nothing on the SBG 5500
any ideas how can i make the VPN work behind this SBG 5500
i really need the AD auth and the device is apparently not able to auth against an AD server so i cannot terminate the VPN on the device itself.
ok so the services are called PPTP adn PPTP_TUNNEL for GREso to make it work fror PPTP VPN on windows just the port forward of TCP 1723 and Firewall rule to allow PPTP service is needed0
- 441 Beta Program
- 534 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
