USG40 - Connect console port for CLI
Hello, I have a Zyxel USG40. In web administration console i mistakenly activated "Authenticate Client Certificates "in" System / WWW / service control ", and I can no longer log into the administration interface. I'm trying to log into the CLI to manually disable this setting, but I don't know how: - The console port is an ethernet connector and not an RS232 ? - I connected an Ethernet / RS232 cable and connected with Hyper terminal (115200-8 bits-no parity-1 stop bit-no flowcontrl) but I do not see anything on the console, even when restarting the USG40 ? However it seems to me that the connection works because when I send a character it seems to answer me with another character? => Can you tell me what I can do because I am really stuck! Thank you, Truly, Gilles
Best Answers
Here are the serial settings for my zywall:
Speed: 115200
Data bits: 8
Stop bits: 1
Parity: None
Flow control: XON/XOF
After loggin in, if you have the credentials execute:
configure terminal
no ip http secure-server auth-client
Don't close serial connection, but check the Web access. If everything is ok, execute "write" in the console terminal and exit the serial console connection.
Regards,
A.
PS: for sure consult the CLI manual for your device and firmware.
Aleftau said:Thank's a lot annoying_t34 for your answer....Do you know how is this cable broached ?...
I don't, but:
https://pinoutguide.com/Net/Cisco-Juiper-Zyxel_RJ45_pinout.shtml
Good luck and regards!
A.
Speed: 115200
Data bits: 8
Stop bits: 1
Parity: None
configure terminal
Regards,
A.
Thank's a lot annoying_t34 for your answer.But it don't work for me : Not possible to connect my terminal (tera term for exemple) to the USG40I try with your config but the same (Xon / Xoff or None for flow control)I think I have a bad cable RJ45 / RS232 (the port cable is RJ45 on the USG40 !)-> But I don't know how to pinout the cable, and don't find documentation about this cable !?Do you know how is this cable broached ?Best regards,Gilles0
I don't, but:
A.
Thank's a lot anno_t34, all is right now !!!
Best regardsGilles0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
