USG Flex 200 VPN Site to Site not connecting
LaserXpress
in Security
I have 2 sites that I have setup USG Flex 200 in. Main site is connected with Fiber and the Secondary site is DSL. The DSL Modem is set to Bridged Mode. I have the PPPoE in the Flex. I have a static block for the secondary site and just a single static for the Fiber. I have setup the VPN tunnel per the instructions online. I have the secondary set to the first static IP address in the block. I have matched the encryption level on both sides. I set the main site pointing to the first static ip address of the secondary site. When I go to connect the sites it just says dialing and never connects. Internet works at both sites. I have rebooted both routers. I am not sure where to start looking. I have setup VPN tunnels for another customer and it worked without a problem.
When I do an ip check the main site lists the static ip address. The secondary site lists the gateway address. Should I use the gateway on the secondary site in the VPN tunnel or the first static ip from the block?
Nevermind. I got it working. I had to use the gateway for the dsl for it to work.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
