Need rack mount kit for my XGS3700-48HP
adminpants
Hi, I have a long APC rack and I'm looking for a rack mount kit for the model in subject
You should find it in the original brown box of your Switch~~0
Both the rail kit and the box got lost some time ago. The rack depth is 55cm. Is there a model number and a supplier you would recommend for Switzerland or Germany?TomorrowOcean said:You should find it in the original brown box of your Switch~~
Hi @adminpants,
Here is the online shop that sells the spare parts of Zyxel products.
Zyxel - LetMeRepair direct (letmerepair-direct.de)
However, unfortunately, the spare parts of XGS3700-48HP is not available now.
From your description above, you would like to have the rail kit.
Therefore, I can provide you the spec of the it:
For the rear bracket:
For the sliding rail:
Hope it helps.
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
