ZyWall SecuExtender Mac Monterey
Bobtatl
Any idea how to make it work on Monterey. I bought a new MPB and after the migration it does not 'open' on the new MBP. I can see it in the applications but when I try to open it, nothing happens. When I try to remove the app it says the app is open and cannot be removed.
Hi @Bobtatl,
We have new Mac SecuExtender for Monterey, please refer link below to download latest version.
https://community.zyxel.com/en/discussion/11958/release-note-secuextender-software-mac-osx-1-2-4-has-been-released#latest
Make sure the app is not running in background if you want to remove previous SecuExtender.
How to check:
By pressing Command + Option + Escape at the same time you'll reveal the Force Quit Applications window, which will show you all the running applications on your Mac and allow you to Force Quit them by selecting them and then pressing the Force Quit option
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
