[NEBULA] NSW 802.1x with Cloud authentication
Kiattikorn
Dear Support,
We have design switch solution with 802.1x and Guest VLAN to provide permission to access wire network.
I'm using NSW100 to enable 802.1x and Guest VLAN then add user account on Nebula Cloud Authentication.
But, after try to login with cloud user on Windows 10 can't access to network just only get Guest VLAN IP please find event log in attached.
In this case we don't have RADIUS in this network we will use cloud authentication instead.
for my question is. does the cloud user database can work with 802.1x on NSW device?
Thank you.
Max
Thank you.
Max
Hello @kiattikorn
Sorry for the late response!
Unfortunately, the NSW's 802.1x port authentication feature does not refer to our Nebula Authentication Server. You will need to use your own private or public RADIUS server for port authentication.
The RADIUS server settings are found under SWITCH > Configure > Switch configuration > Authentication servers.
If necessary, we can add this into the ideas forum section to influence the odds of adding this into future updates.
Best regards,
Barney Gregorio
Hi Barney,
Sure, this solution very helpful when we propose with startup company that they haven't use RADIUS.
Please help to keep this into ideas forum.
Thank you.
Max0 -
Hi @kiattikorn
There are several companies which offer "Radius as a Service".
Please send to me a private message if you are interested.
Regards
- 588 USG FLEX H Series
- 477 News and Release
