Router(config-wlan-radio test_24G)# output-power 50% % Command removed due to the platform upgrade.
Hi @Dzmitry
Thank you for reporting the observation.
The command has changed the category, the current settings is at wlan-slot.
If you want to edit radio 2.4GHz the command will be slot1 and 5GHz is slot2.
Here is the example for changing the power of radio 5GHz:
Router# configure terminal
Router(config)# wlan slot2
Router(config-wlan-slot)# output-power 30dBm
Don’t hesitate to get back to me if you need any more information.
Thank you
Regards,
Bella
Hi @Dzmitry
Thank you
Regards,
Bella
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
