guest wifi not broadcasted - NWA50AX
Using NWA50AX and managed via Nebula
2 SSID
primary one is connected to corporate LAN and can connect and access internet
seconday is guest network as set in Nebula but not advertised at all so can not connect
I have confirmed in Nebula the SSID is enabled and enabled to broadcast
2 SSID
I have read that NWA50AX is a less expensive product and doesn’t support guest network, even if you can set up such a configuration with Nebula.0
Hi @AxL1971 ,
Thank you for raising questions.
Because NWA50AX and NWA55AX are designed for small business,
they don’t support Guest network.
The function table can be found in Nebula: Help>Device function table>SB Access point
if you want to purchase AP with Guest network function,
Please refer NWA110AX or NWA1123ACv3:
https://download.zyxel.com/NWA110AX/datasheet/NWA110AX_8.pdf
https://download.zyxel.com/NWA1123ACv3/datasheet/NWA1123ACv3_2.pdf
Thank you.
Silvia
- 431 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 359 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
