GS1900-E24 perfectly running but unreacheable via https
Hi. I am searching some help for this problem. My switch is perfectly running as switch, but I am not able to reach it via web interface. Firstly I tryed at last saved address, secondly after keepeng pressed reset button for 15 seconds, (assuming 192.168.1.1 default address) I set my PC to 192.168.1.10 but nor me nor ZON utility are able to reach it. Ping does not reply, admin web interface the same.
What can i do to understand the problem?
Edit: found after seeing that if after its reset it find a DHCP it get an IP, thank you
Hi @franz,
Welcome to Zyxel community!
It's glad to see your issue has been solved.
Our switch will try to get DHCP IP after you reset to default.
If it get a DHCP IP, you may access device WEB GUI with the DHCP IP.
If it can't get DHCP IP, you may access device WEB GUI with 192.168.1.1.Zyxel Melen0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 457 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
