Cannot log in to the router
Cuggy
Cuggy Posts: 2 image  Freshman Member
The USG60 firewall is set to ip 192.168.1.1 while the router is set to IP 192.168.1.4
As soon as I try to enter the modem through the IP 192.168.1.4 page not available appears.
Because?
  • valerio_vanni
    valerio_vanni Posts: 157 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    You should explain better your setup: how are device connected?
    Which interface (lan, wan etc) is set on those addresses, etc.
  • Cuggy
    The router with IP 192.168.1.4 is connected to the Firewall in the Wan1 port.
    The firewall that has IP 192.168.1 is connected through LAN1 port to a switch.
    If I set automatically IP and DNS on PC, it give me the following Gateway 192.168.1.1
    However, if I try to enter the 192.168.1.4 router from a PC, it won't let me connect.
    How can I access the Router through the LAN if the IP 192.168.1.4 is not found by PC?
    PeterUK Posts: 4,416 image  Guru Member
    So you have set the WAN as 192.168.1.0/24 and the LAN as 192.168.1.0/24 same subnet? That not going to work if you unplug the WAN you could be able to login and change the subnet LAN to some thing other then 192.168.1.0/24.
    Are you not about to to set your ISP to modem mode or bridge mode?
  • Zyxel_Cooldia
    Hi @Cuggy,
    Wan and lan1 subnet is overlap. Please change USG lan 1 to other subnet.
