What would happen to communicatios if a Zyxal 24 1gb switch lost its config info
paulmac
paulmac Posts: 6 image  Freshman Member
edited August 2022 in Switch
IF a Zyxal switch has been losing its config data and needing re-inputting.
Two Vlans exist on this switch default VLAN 1 and VLAN 20. Another switch is connected via a port using a trunk, VLAN 1 and VLAN 20 devices also exist on this second switch. Would Devices on VLAN 20 (192.168.2.x) and VLAN 1 (102.168.1.x) still be able to communicate with each other if Switch 2 lost its config data?. inter-switch and intra-switch ?
  • Zyxel_JonasTan
    Zyxel_JonasTan Posts: 98 image  Zyxel Employee
    Welcome to Zyxel community!
    Based on your description, if Switch 2 loss the configuration and restore to the default configuration. All VLAN 20 member will be unreachable except for VLAN 1 member. Because VLAN 1 is the default VLAN.
    For recovering the Switch 2 configuration, assuming that Switch 1 & Switch 2 configuration is the same.
    1. Download the configuration of Switch 1.
    2. Use a notepad++ (software) and modify the management IP for Switch 2 then save.
    3. Upload the configuration file to Switch 2.
    Note: Remember to backup the configuration file after finish setting up the Switch.
    Hope it helps.
    Zyxel_Jonas
  • Zyxel_JonasTan
    Hope it helps.
    Zyxel_Jonas
  • paulmac
    Thanks jonas that is very helpful. When switch 2 loses its config would the fact that VLAN 20 devices on switch 2 having static IP addresses within the 192.168.2.x (netmask 255.255.255.0) range mean that they would still be able to communicate with with VLAN 20 and VLAN 1 on both switches or would this make no difference ?
  • paulmac
    The dhcp server and router are connected to switch 1 by the way.
  • Zyxel_JonasTan
    Hi @paulmac,
    Good question.
    If Switch 2 loses the configuration and restored back to default configuration the Switch 2 will get an IP address of 192.168.1.x from the DHCP server (VLAN 1) dynamically, due to Switch 2 had detected that there is a DHCP server connected in the environment.
    But if there is no DHCP server, Switch 2 will have a Static IP address of 192.168.1.1 (default).
    For the communication, as Switch 2 had been restored to the default configuration. Switch 2 will only have VLAN 1 to communicate to.
    Hope the above is clear.
    Zyxel_Jonas
  • paulmac
    Thanks jonas one final question
    If a Zyxal switch suffers a power outage, is it normal for the event log yo be wiped ?
  • Zyxel_Ryan
    Zyxel_Ryan Posts: 72 image  Zyxel Employee
    First Answer First Comment Friend Collector
    Hi @paulmac
    Zyxel switch backup its log every one hour.
    That is, if switch suffers power outrage and shut down before the next hour of saving log, the event log in this period will be wiped.
    Ryan
  • paulmac
    Where is it backed upto ? how cam I access the backup ?
  • Zyxel_JonasTan
    Zyxel switch writes the LOGs into the flash memory every one hour.
    If the switch shutdown or reboots within one hour, all of the event log will be erased in that period of time.
    Zyxel_Jonas
  • paulmac
    So if someone has deleted the log there is no way of getting it back ?
  • Zyxel_Ryan
    edited July 2018
    Hello @paulmac
    Maybe I can explain it more clear by the following example.
    We assume the switch boots up at 10:00 am.
    That is, the saving time will be 11:00 am, 12:00 pm, 1:00 pm....and so on. (Once a hour)
    If port link up/down happens at 10:15 am and the power is off accidentally at 10:50 am, the port link up/down log will not be recorded because it happens BEFORE the next log saving time, which is 11:00 am.
    On the contrary, if the power is off at 11:10 am, because it happens AFTER the next log saving time, the port link up/down log will be recorded successfully.
    Lastly, if you wish to prevent log events lost like the situation mentioned above, we recommend you to use syslog server.
    Syslog server records all logs from switch immediately when events happen.
    By the way, if you would like to review the logs that have been recorded successfully.
    You can use web GUI or command to review them.
    1. Web GUI: Go to: Management > System Log
    2. Command: #show logging page
    Hope it help!
    Ryan
