XMG3927-50A Firmware
bananacakes
Hi there
I have recently purchased a XMG3927-50A Gateway router. However I am unable to find it on the website and only managed it coming in via an external google search.
I'm wondering where the latest firmware can be found, after an extensive (google) search I manged to find the manual but I suspect there has been a firmware update given the version numbers listed, so is there a link to firmware for this router anywhere ?
Hello @bananacakes
There is some firmware for your device from 2019 in ftp://ftp.zyxel.com/XMG3927-B50A/firmware/ as version 5.13 (ABMT.0)C0
I hope that is helpful.
Kind regards,
Tony0
Hello @bananacakes
Kind regards,
Tony0 -
Thanks Tony, that was helpful, seems I have the latest firmware after all, but it was useful to know where to get it should I update, I understand there is a update due in July (2021) to fix a low lever security issue, am i right to believe the same url will take me to thattonygibbs16 said:Hello @bananacakes
Kind regards,
Tony
Hello @bananacakes
You are welcome.
Any new firmware could be in that folder or under the Downloads & Resources at https://service-provider.zyxel.com/global/en/products/dsl-cpes/gfast/gfast-bridgesgateways/xmg3927-b-series
Kind regards,
Tony0 -
I cannot find firmware for this router anywhere - please advise ?0
try this address :https://www.zyxel.com/euosearch/dl-search.aspx?mci_country=uk&mci_lang=en&keyword=xmg3927&submit=Search
I have download 5.17 on 2 3927's and seems to be OK on gfast0
- 588 USG FLEX H Series
- 477 News and Release
