GS1900-24 firmware 2.70(AAHL.0)C0 endless login redirects
  • mMontana
    mMontana image  Guru Member
    @Zyxel_Jonas any ETA for a... non-beta release?
  • Zyxel_Jonas
    Zyxel_Jonas image  Zyxel Employee
    25 Answers First Comment Friend Collector Fifth Anniversary
    Hi @Rveupen,
    I too have a GS1900-24E and updated it with firmware GS1900-24E_2.70(AAHK.0)C0.
    I also have the login redirect to the login screen.
    I have not yet downgraded to GS1900-24E_2.60(AAHK.2)C0 yet and would likt to try the beta firmware too.
    Welcome to Zyxel Community!
    I had PM you the beta firmware.
    Please check your inbox.
    Jonas,
    Jonas,
  • Zyxel_Jonas
    Hi @mMontana,
    I would like to inform that the estimated time of the official release is the end of January.
    Jonas,
    Jonas,
  • ToNKeY
    ToNKeY image  Freshman Member
    Friend Collector
    Hi @Zyxel_Jonas,
    unfortunately I have the same issues with instant auto-logout running firmware 2.70 on my private GS1900-24E and some GS1900-8HP and GS1900-10HP at work. Please provide me the beta firmware resolving this issue.
    Many thanks in advance.
    Kind regards
    Markus
  • BolshoiBob
    BolshoiBob image  Freshman Member
    I tried downgrading to the 2.60 version and it failed.  Can I get a copy of the beta software to make the switch usable?
  • Zyxel_Jonas
    Hi @ToNKeY,
    Kind regards
    Markus
    Jonas,
    Jonas,
  • Zyxel_Jonas
    Hi @BolshoiBob,
    May I know the specific model of your GS1900, and I'll PM you the beta firmware after then.
    Could you also provide the 2.60 version you were using and a screenshot of the error message?
    Because I don't see any problem in my local LAB.
    Jonas,
    Jonas,
  • Zyxel_Jonas
    Hi Guys,
    I would like to announce that the official firmware is released.
    It can be downloaded from our global website: Download Library | ZyXEL
    Thank you for your patience and support.
    Jonas,
    Jonas,
  • MichaelB
    MichaelB image  Freshman Member
    edited February 2022
  • greenbdc
    greenbdc image  Freshman Member
    endless login redirects from my Gs1900-24
    F.E
