Default DNS resolution on USG FLEX
valerio_vanni
valerio_vanni Posts: 157  Master Member
5 Answers First Comment Friend Collector Third Anniversary
How does DNS resolution work, by default?
System -> DNS config page is absolutely empty, I haven't set a forwarder yet. So I would expect the device not to resolve addresses.
But, instead, it resolves. It can act as DNS server for clients, it resolves in CLI.
That's not a real issue but a thing I'd like to understand.
How does it do? Has it some default server address hardcoded? Does it use roots?
Query result in CLI doesn't help understanding where the answer come from:
"Received 334 bytes from 127.0.0.1#53 in 68 ms"
    PeterUK Posts: 4,050  Guru Member
    It dose recursive DNS with default root
    Its a good thing really as if you got a IP setup with DNS you can't make the USG be a recursive DNS only.
  • valerio_vanni
    Was it the same in previous series?
    yes
