VMG1312-T20B Help please
Nixon
VMG1312-T20B V5.30 (ABSB.0) C0 after firmware update V5.30 (ABSB.5) C0 password from back label does not match! What to do? Help please
Hi there
Have you tried reset the device to factory default by pressing the Reset button over 5 seconds?0
Hi there
Have you tried reset the device to factory default by pressing the Reset button over 5 seconds?0 -
reset from the overload button did not help. The router reboots, but the password from the back label does not work. Need *.rom loader сброс с кнопки перегрузка не помогло. роутер перегружается, но пароль с задней этикетки не подходит. Нужен загрузчик *.rom
-1 -
SEJ said:Hi there
Have you tried reset the device to factory default by pressing the Reset button over 5 seconds?reset from the overload button did not help. The router reboots, but the password from the back label does not work. Need *.rom loader сброс с кнопки перегрузка не помогло. роутер перегружается, но пароль с задней этикетки не подходит. Нужен загрузчик *.rom
-1 -
Hello! Did you solve you problem?
остаётся выбросить на помойку и купить новый роутер другого производителя
-1
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
