RDP connection to Windows Server 2016 keeps disconnecting
I am using router ZYXEL ZYWALL USG 20.
I have configured NAT to forward RDP connection to a WINDOWS SERVER 2016 driven server.
Session is established normally, but it is interrupted many times, more often after loss of focus for a few seconds, but also during normal usage.
Yesterday I replaced ZYXEL’s router with router MIKROTIK. RDP session after that worked normally without interruptions.
I upgraded USG with latest firmware version available on Zyxel’s web pages, but the problem persists.
Hi @svalbard
Welcome to Zyxel Community.
According your RDP disconnect issue should coming from the UDP session time is expired.
In the default setting the UDP session time out is 9 session.
It means If UDP session is idled over 9 seconds, the session will disconnect.
You can go to Firewall > Session Control > Extend UDP session timeout as 300 seconds.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
