IPSec VPN Profile for IOS with FW 5.2
Hi
I test the new native IPSec v2 connection to an Ipad with FW 5.2 (great work, BTW 👍)
How can I get the config to my Ipda? At the end of the "quick setup" I can export the config, but can I also get it from the webinterface when I log in with the VPN user? (self-service)
This was possible with the old L2TP VPN over the "Configuration Provisioning" option.
Currently I don't see an option for this?
Mario
Hi @Mario
VPN configuration provision in login portal page only support for IOS, since iPadOS is no belonging to iOS, so the session page will not display the download button to you.
In 5.20 version, wizard will generates different platform configuration for Windows/IOS/MacOS/Android VPN client. You can download them when creating VPN rule by wizard.
Also if user could download all of platform VPN configuration after logging into system, then will much friendly. So I reported is as idea as requirement.0
It looks you have to add IKEv2 configuration manually....since iPadOS is neither iOS or macOS.
You can export the certificate from firewall, and open it by Safari.
And then go to create IKEv2 VPN rule on your iPad after trusting the certificate.
Hi @CHSThanks for your reply. At 5.2 you have the optoin to export "RemoteAccess_iOS_301.mobileconfig" at the end of the quick setup (small icon on the left side) .You can import this file on IOS and just enter username and password, then the vpn works.I like to have an option to allow the users to log on on the firewall directly on IOS / Android and get the "RemoteAccess_iOS_301.mobileconfig" or "RemoteAccess_ANDROID_270.sswan" for IOS or Android.
Hi @Zyxel_StanleyThis is what I expect, but on my Ipad 6. gen with 15.2.1 with safari I don't have the option to download the profile:
Is this a bug?
Hi @Mario
- 439 Beta Program
- 2.8K Nebula
- 196 Nebula Ideas
- 6.3K Security
- 477 USG FLEX H Series
- 312 Security Ideas
- 82 Switch Ideas
- 45 Wireless Ideas
- 284 Service & License
- 446 News and Release
- 4.3K FAQ
- 93 Security Highlight
