2FA Google Authenticator on VPNSSL
Hi @itariant
Please refer to this FAQ link about “How to Use Two Factor with Google Authenticator for VPN Access?”:
BTW, if you build VPN tunnel by SSL VPN or L2TP VPN, you have to enter the correct URL for entering 2FA verification code.
please can I ask … if I understand correctly that it is possible to connect using the SecuExtender SSL client (not necessary IpSec client) ?
It is possible for SSL VPN implement an automatic script that opens the browser after login on the page to insert 2FA code ?
Thank you !0 -
Hello @kyssling
Thanks for your inquiry. According to the current VPN 2FA behavior, the SSL VPN client still needs to manually enter the correct URL for entering the verification code, but the SecuExtender IPsec client won't. Thanks.
- 588 USG FLEX H Series
- 477 News and Release
