USG20-VPN can't upload configuration
Does the file you've uploading have the same name of one into the firewall?
I tried it as the same name and adding a "1"onto the filename, no difference
There's any non-ASCII character into configuration file?
Nothing that stands out scrolling through in Textpad.https://www.dropbox.com/s/zel2gjr8a2vz4vf/startup-config1.conf?dl=0
Hi @Fullbore,When I upload your configuration file "startup-config1.conf" to USG20-VPN(firmware 5.20), it shows the following error message. We're investigating this issue.
To solve the issue temporarily, edit the configuration file and delete three lines. The file can be uploaded to the device and applied successfully.0 -
That is uploading, but as of now it's been uploading for 3 hours!This seems a very long time0
- 6.9K All Categories
- 2 Education Center
- 1.4K Nebula
- 34 Nebula Ideas
- 40 Nebula Status and Incidents
- 4K Security
- 203 Security Ideas
- 753 Switch
- 31 Switch Ideas
- 637 WirelessLAN
- 10 WLAN Ideas
- 4.6K Consumer Product
- 105 Service & License
- 224 News and Release
- 39 Security Advisories
- 522 FAQ
- 239 Nebula FAQ
- 121 Security FAQ
- 73 Switch FAQ
- 67 WirelessLAN FAQ
- 6 Consumer Product FAQ
- Documents
- 30 Nebula Monthly Express
- 45 About Community
- 32 Security Highlight
