GS-105B v3 power supply
Hi @Nippes,
Welcome to Zyxel Community!
The dimensions and polarity of the GS-105B v3 plug is 2.1/5.5mm, positive on center pin.
Hope it helps.Zyxel Melen1
Hi @Nippes,
Hope it helps.Zyxel Melen1 -
Yes it helps. In the meantime I found an old Sega power supply with the same plug dimensions and it fit. I cut the cable, now knowing the polarity connected it to a USB plug and it works. Thank you.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
