Need recomendation for replacement of Orbi
I am also a bit confused about the Zyxel mesh licensing. Since I currently pay for a gold subscription on my ATP200 does that cover the mesh license or is that separate?
Thanks in advance for the help.
Regards,
Alan
Hi @Alanl
Thank you for raising question here.
If you just need one peer of mesh the license isn’t necessary,
more than two peers needs to purchase license.
Please follow below steps to configure AP mesh.
we also suggest you to use Nebula control your AP,
in Nebula mode the mesh function doesn't need license and with no limit of mesh amount.
Please refer this post to configure mesh:
We would recommend you WAX510D or WAX610D to be controlled by your ATP200,
they are AX standard AP with better throughput and more functions.
The biggest different between two APs is WAX610D has LAN port, therefore, it supports wireless bridge.
Please refer the datasheet for both of APs,
https://download.zyxel.com/WAX510D/datasheet/WAX510D_5.pdf
https://download.zyxel.com/WAX610D/datasheet/WAX610D_5.pdf
You may also share with us the usage scenario, and we can help to suggest.
Thank you.
Silvia
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
