USG20-VPN can't upload configuration
Fullbore
Fullbore Posts: 7 image  Freshman Member
I saved startup-config from our existing USG20-VPN but when I try to save it to a new USG20-VPN I get a Error Message box-
errno: : var errno0=
errmsg: var zyshdata
Both devices are running the latest firmware.
  • mMontana
    mMontana Posts: 1,499 image  Guru Member
    Does the file you've uploading have the same name of one into the firewall?
  • Fullbore
    I tried it as the same name and adding a "1"onto the filename, no difference
  • mMontana
    There's any non-ASCII character into configuration file?
  • Fullbore
    Nothing that stands out scrolling through in Textpad.https://www.dropbox.com/s/zel2gjr8a2vz4vf/startup-config1.conf?dl=0
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,492 image  Zyxel Employee
    When I upload your configuration file "startup-config1.conf" to USG20-VPN(firmware 5.20), it shows the following error message. We're investigating this issue.
    To solve the issue temporarily, edit the configuration file and delete three lines. The file can be uploaded to the device and applied successfully.
  • Fullbore
    That is uploading, but as of now it's been uploading for 3 hours!
    This seems a very long time
