[NEBULA] Switch client information
Bronco
Bronco Posts: 15 image  Freshman Member
First Answer First Comment Friend Collector First Anniversary
edited April 2021 in Nebula
Is there a way to see all client devices that are connected to a NSW port?
It is a bit troublesome to only see one client connected via the switch port configuration page through LLDP.
Thanks,
  • Zyxel_Dean
    Zyxel_Dean Posts: 237 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi ocean77
    You can go to Switch -> Monitor ->Client to view the table of all the clients MAC addresses direct and indirectly connected to the switch ports.
  • RUnglaube
    RUnglaube Posts: 135 image  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    Hey @Nebula_Dean I've noticed that Switch > Monitor > Clients shows the devices connected to my non-administrable switch (that is connected to my NSW200) as its own clients. Shouldn't be better just to see those devices that are directly connected to it?
    "You will never walk along"
  • Zyxel_Dean
    @RUnglaube
    It is true NSW will show the MAC of other clients from a different switch if your topology has another one connected to it. Basically what it does is it shows is the entries from the MAC table and records them.
    However, to show only the devices are connected to it, you may have to use the authors way of seeing it through LLDP, I'll check if theres an enhancement in this function.
  • RUnglaube
    Great! I'll be very attentive to check if you guys come up with an idea
Nebula Tips & Tricks
