USG20-VPN configuration upload time
Now on to day 3!
What firmware version and browser you are using?
Can you try to browse in private mode to login Web-GUI and upload config file again to see if it works?
V5.20(ABAQ.0) / 2022-01-06 00:51:36 and Edge.It appears after power cycling that the upload completes successfully but the upload box with the times just keeps running so there is no indication that the upload has actually finished.1
Hi @FullboreThe uploading stuck symptom might be caused by PC or browser cache. So, if you would like to log in to local Web-GUI next time, we suggest you can use the browser in private mode. If it still has a problem you can clean your cache(PC and browser) and see if it works
- 6.9K All Categories
- 2 Education Center
- 1.4K Nebula
- 34 Nebula Ideas
- 40 Nebula Status and Incidents
- 4K Security
- 203 Security Ideas
- 753 Switch
- 31 Switch Ideas
- 637 WirelessLAN
- 10 WLAN Ideas
- 4.6K Consumer Product
- 105 Service & License
- 224 News and Release
- 39 Security Advisories
- 522 FAQ
- 239 Nebula FAQ
- 121 Security FAQ
- 73 Switch FAQ
- 67 WirelessLAN FAQ
- 6 Consumer Product FAQ
- Documents
- 30 Nebula Monthly Express
- 45 About Community
- 32 Security Highlight
