Zyxel EX5501-B0
Tascam
in Home Router
I bought a ZYxel router modelEX5501 BO. The seller told me that it was an open router. When the router arrived at my address, I determined that it was a router for the Telia operator, and I could not access it via IP address (192,168 .01) .How did the seller cheat me and I can't get to it, is there a way to put open firmware in it or how could I use it as an AP depending on the situation?
. Please for any help.
Thank you.
Thank you.
Is there a way to forcibly insert the factory firmware?
Hi
Can you please provide the serial number of this device? You can find it on back label of device.
I have a similar issue. Took over a Zyxel router from the previous owner of our house. It clearly has Allente installed firmware on it that doesn’t allow a sim from another provider to be used in the external Zyxel antenna.
KR
Stefaan
Hello Stefaan @Sma
Welcome to the forum.
The EX5501-B0 does not have a SIM slot in it, see https://www.electronicfrontier.co.uk/wp-content/uploads/2022/03/EX5501-B0_Datasheet_4-min.pdf
Kind regards,
Tony
ex5501的固件在哪,是什么处理器
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
