In vpn monitor first letter of user names is missing
valerio_vanni
valerio_vanni Posts: 156  Master Member
5 Answers First Comment Friend Collector Third Anniversary
I find that, often but not always, in vpn monitor I see user names without their first letter.
I attach an example: all miss the first letter.
Tunnels work.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @valerio_vanni,
    Welcome to Forum,The filed only display client names if "they're using EAP or X-auth" for Authentication.if not, the filed will be empty.
    It seem there are different VPN Profile in your picture.Could you kindly provide Configuration File in Private Message ? We can assist you to check .
    Kevin
  • valerio_vanni
    They use x-auth. #5 is a site-to-site VPN, is fine that it has no user name.
    The issue is on the other lines, perhaps I didn't explain well what "without their first letter" means.
    User names are piergiorgio, sara, valerio, elena, and appear as iergiorgio, ara, alerio, lena.
  • zyman2008
    zyman2008 Posts: 232  Master Member
    25 Answers First Comment Friend Collector Seventh Anniversary
    valerio_vanni,
    There are CLI to check the logon users.
    # show users all | xml
    # show sa monitor | xml
    If the username from CLI is also lost the first letter. That's function bug.
    If only the display on GUI lost the first letter. That's GUI issue. You can try to flush cache on browser to try again or use different type of browser (Firefox, Chrome, MS Edge ...) to check if any different.
  • Zyxel_Kevin
    edited January 2022
    Hi @valerio_vanni,
    Does your user from AD/LDAP?
    The filed always show "Login name" and It would the same as "Firewall ext-user" .
    It won't show first letter.
    Kevin
  • valerio_vanni
    In CLI usernames are correct.
    I tried to change browser and PC (one is Firefox on Linux, the other Edge on Windows 10) and I saw a difference: in the first 2 usernames (on 2) were wrong, in the second only one.
    After half an hour, things are changed: in the first only one wrong, in the second both wrong.
  • Zyxel_Kevin
    I cannot reproduce the issue with 5.10/5.20 even I used Italian in Browser.
    Please kindly provide information that I mentioned in PM. Thank you.
    Kevin
  • Zyxel_Kevin
    Hi @valerio_vanni
    Thank your information.I have reported the issue to internal
    Due to Chinese New Year Eve. We will Out of office next week.
    Thanks your patience.
    Kevin
  • Zyxel_Kevin
    Hi @valerio_vanni
    Could you kindly provide Remote GUI Access ?
    Our Team would like to remote and check the issue.
    Please send the IP,Account,Pwd in Private Message.
    Thank you.
    Kevin
