Changed the Certificate on the VPN Gateway
Hi I'm pretty inexperienced with Zyxel problems. I was trying to make some changes on my companis Zyxel VPN and accidentally changed the certificate on the VPN Gateway tab. Now I cannot acces the VPN remotely anymore. How can I get back into the Hub and change it back.
Is there a possibility to access the router over a wired connection?0
Hi @CP98,
Yes,You could use wired connection to access Firewall.Please kindly find following.
1)set the NIC as 192.168.1.X(mask:255.255.255.0) and plug cable to Firewall first LAN Port.
2)Open the browser,access https://192.168.1.1 , You will see the Firewall login pages.
Above are default IP Address. You could access your own IP address if you have changed the default.
Kevin0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
