Changed the Certificate on the VPN Gateway
CP98
CP98 Posts: 5 image  Freshman Member
Hi I'm pretty inexperienced with Zyxel problems. I was trying to make some changes on my companis Zyxel VPN and accidentally changed the certificate on the VPN Gateway tab. Now I cannot acces the VPN remotely anymore. How can I get back into the Hub and change it back.
  • CP98
    Is there a possibility to access the router over a wired connection?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 986 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    edited January 2022
    Hi @CP98,
    Yes,You could use wired connection to access Firewall.Please kindly find following.
    1)set the NIC as 192.168.1.X(mask:255.255.255.0) and plug cable to Firewall first LAN Port.
    2)Open the browser,access https://192.168.1.1 , You will see the Firewall login pages.
    Above are default IP Address. You could access your own IP address if you have changed the default.
    Kevin
