Why Are There 2 Triangle Light Indicators For Every Port
businessuer
For zyxel switches, why Are There 2 Triangle Light Indicators For Every Port?
I understand that those pointing to the top refers to the interface on top.
I understand that those pointing to the bottom refers to the interface on bottom.
But why 2 triangles for each interface?
@businessuer
The green LED means link on 1G and the left one of amber means on 100M, you can refer to our user guide page 43.
XGS4600-32_V4.70_Ed1.pdf (zyxel.com)
Also on front panel sticker has also poin it out.
@businessuer
I'm not quite sure what you mean, which model are you use?0 -
Zyxel_Chris said:@businessuer
In the circled portion, there are 2 triangles up and 2 triangles down.
I notice that when the interface is up, only 1 triangle will light up.
What is the other triangle for?
@businessuer
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 500 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
