Why Are There 2 Triangle Light Indicators For Every Port
businessuer
in Switch
For zyxel switches, why Are There 2 Triangle Light Indicators For Every Port?
I understand that those pointing to the top refers to the interface on top.
I understand that those pointing to the bottom refers to the interface on bottom.
But why 2 triangles for each interface?
Zyxel_Chris said:@businessuer
I'm not quite sure what you mean, which model are you use?
In the circled portion, there are 2 triangles up and 2 triangles down.
I notice that when the interface is up, only 1 triangle will light up.
What is the other triangle for?
@businessuer
The green LED means link on 1G and the left one of amber means on 100M, you can refer to our user guide page 43.
XGS4600-32_V4.70_Ed1.pdf (zyxel.com)
Also on front panel sticker has also poin it out.
Chris
- 6.8K All Categories
- 1.3K Nebula
- 26 Nebula Ideas
- 28 Nebula Status and Incidents
- 3.8K Security
- 199 Security Ideas
- 691 Switch
- 25 Switch Ideas
- 568 WirelessLAN
- 8 WLAN Ideas
- 4.5K Consumer Product
- 95 Service & License
- 212 New and Release
- 35 Security Advisories
- 479 FAQ
- 216 Nebula FAQ
- 109 Security FAQ
- 72 Switch FAQ
- 66 WirelessLAN FAQ
- Documents
- 20 Nebula Monthly Express
- 40 About Community
- 31 Security Highlight
