Zertifikat wird im Browser nicht erkannt
yes i type always tthe IP only and not a Namehere is a SC or do you need more ?just let me know.it seems to be an older certificate than i created because i did it days before and there is another date on it.i´ll add also the certificates of the AP
Hi @Mike2301
The browser still used the default certificate to communicate with AP.
As I mentioned before, please go to Configuration > System > WWW > Service Control > HTTPs, and change the "Server Certificate" to NWA55AXE that you created.
Joslyn0 -
Hi Joslyn,We hit the target
I thought this is already the IP-Adress and had no knowledge about where to look what Certificate is in use.Thank you very much to solve my Problem which tooks me Days.i give you and all other Readers here some mor Screenshoots because i think i´m not alone with that issue
Thanks in advance Joslyn and nice greetings from Austria (EUROPE).
Hello Joslyn,We hit the Target
I had no Knowledge that the wrong Certificate from AP is used but now i found it and everything is clear now. i had there IP_Adress and thougt it uses the one i have created bevore. my Mistake.Will give you 2 Screenshoots to show the Result. I think this will be very usefull for others too
Tooks me Days to find the right Solution. Thank you in Advance and nice Greetings - Mike from Austria (EUROPE).
- 3K Nebula
- 222 Nebula Ideas
- 621 USG FLEX H Series
- 350 Security Ideas
- 53 Wireless Ideas
- 488 News and Release
- 108 Security Highlight
