USG 310 - public IP behind PPPoE
how to correctly configure public IP behind PPPoE with dynamic IP? This is my configuration withou public IP:
! model: ZyWALL 310
! firmware version: 4.70(AAAB.0)
interface-name ge1 wan1
interface-name ppp0 wanTvinet
account pppoe TVINET
user ***
encrypted-password ***
authentication chap-pap
compression no
idle 0
interface wan1
type external
description TVINET VDSL
upstream 10000
downstream 50000
mtu 1500
ping-check default-gateway method icmp period 30 timeout 5 fail-tolerance 5 probe-condition any
no ping-check activate
ip address 0.0.0.0 0.0.0.0
interface vlan848
port wan1
vlan-id 848
description TVINET_VLAN_848
ip address dhcp metric 0
upstream 1048576
downstream 1048576
mtu 1500
type external
ip rip send version 2
ip rip receive version 2
ip ospf priority 1
ip ospf cost 10
interface wanTvinet
bind vlan848
description PPPoE TVINET
connectivity nail-up
account TVINET
metric 0
upstream 1048576
downstream 1048576
mtu 1492
ipv6 nd ra accept
Connection itself works fine, but I need to set the public IP - according to my ISP, they routed my public IP behind the dynamic IP address received on wanTvinet interface. Now I am not sure, where to set the public IP?Accepted Solution
Hi @Lukas
Please help to log a ticket, so we can do a deeper Packet-Trace analysis and assist you:
https://support.zyxel.eu/hc/en-us/requests/new?ticket_form_id=114093996354
Regards,
Tobias0
you may use a SNAT in Policy Routing to send out WAN Traffic with Public IP from your ISP.
https://support.zyxel.eu/hc/en-us/articles/360001440613-Policy-Routes-USG-VPN-ATP-Different-scenario-usages-configurations
If you need to configure it on Dial-In, then these are the steps:
https://support.zyxel.eu/hc/en-us/articles/360005190500-Instructions-for-setting-up-a-hardware-ZyWALL-USG-series-gateway-using-a-static-IP-address-for-connecting-to-the-Internet
Kind Regards,
Tobias0 -
Hi @Zyxel_Tobias,
Thank you for your answer.
I know how to configure pulic IP on direct ethernet connections, but I am not sure where to put public IP in this situation - on wan1 or vlan848? First thing I need to test is simple PING from Internet. I have tried to set the public IP on wan1 and then on vlan848 interface, but the PING did not work (even with temporary disabled firewall).
Hi Lukas,
on WAN1 should be fine, VLAN is only the Dial-in linking object here.
Regards,
Tobias0 -
Thank you, @Zyxel_Tobias
I have put public IP (withou gateway - ISP did not privede any gateway) to the wan1 interface:interface wan1type externaldescription TVINET VDSLupstream 10000downstream 50000mtu 1500ping-check default-gateway method icmp period 30 timeout 5 fail-tolerance 5 probe-condition anyno ping-check activateip address *.*.*.* 255.255.255.254!
I have temporary disabled firewall, but the ping from outside is not working. Ping from LAN side is working fine. What else should I check, so that the ping from outside Internet is working?0 -
Hi @Lukas
Regards,
Tobias0
- 601 USG FLEX H Series
- 480 News and Release
