USG 310 - public IP behind PPPoE
Lukas
Lukas Posts: 13  Freshman Member
how to correctly configure public IP behind PPPoE with dynamic IP? This is my configuration withou public IP:
! model: ZyWALL 310
! firmware version: 4.70(AAAB.0)
interface-name ge1 wan1
interface-name ppp0 wanTvinet
account pppoe TVINET
user ***
encrypted-password ***
authentication chap-pap
compression no
idle 0
interface wan1
type external
description TVINET VDSL
upstream 10000
downstream 50000
mtu 1500
ping-check default-gateway method icmp period 30 timeout 5 fail-tolerance 5 probe-condition any
no ping-check activate
ip address 0.0.0.0 0.0.0.0
interface vlan848
port wan1
vlan-id 848
description TVINET_VLAN_848
ip address dhcp metric 0
upstream 1048576
downstream 1048576
mtu 1500
type external
ip rip send version 2
ip rip receive version 2
ip ospf priority 1
ip ospf cost 10
interface wanTvinet
bind vlan848
description PPPoE TVINET
connectivity nail-up
account TVINET
metric 0
upstream 1048576
downstream 1048576
mtu 1492
ipv6 nd ra accept
Connection itself works fine, but I need to set the public IP - according to my ISP, they routed my public IP behind the dynamic IP address received on wanTvinet interface. Now I am not sure, where to set the public IP?
