Content filter https issue
IT_Field_Support
in Security
Router : USG40w
firmware : 4.65 then 4.70
We notice that all site with "https" were blocked. Investigating the firewall, I noticed that many website like google were classified as "unrated". So I checked with the category tester and I got an error. I think it is the issue.
I did the upgrade to 4.70 but the issue remain the same.
Please help,
in case of further support is needed here, please log a ticket, we may need to check it in a remote session together with DNS Setting check, CF Module, License, Regional Server, and more.
Ticket: https://support.zyxel.eu/hc/en-us/requests/new?ticket_form_id=114093996354
Regards,
Tobias0
I have many website which are unrated I don't understand why...0
Hi IT_Field_Support,Please check your content filter settings. Provided you have purchased an actual UTM license, every web access will be checked against a rating. And you have to lay down the rules, how USG should act with rated and unrated websites:If you would like to pass unrated website calls, set the action to "Pass".0
Hi,Thanks for the answer. I already did that to allow people go on unrated website.But this is a workaround.I would like to know why my USG cannot check the category of a website. I think Google cannot be an unrated site.Still have an issue here.Thanks0
Indeed, that's strange.Did you check your licensing registration state, that you are receiving all ratings and signatures regularly? You could also push the Refresh Button.0
You could also try to manually update your IDP/AppPatrol version to see whether it finds the Zyxel server and works correctly:0
Regards,
Tobias0
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 387 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
