Upgrade from USG60 til USG FLEX 200
You cannot upload the same configuration file, but you can convert it.Look at this, the path from USG 60 to FLEX 200 seems supported:
Hello, thank you for this. I applied the convertor to my USG60 startup-config file and uploaded it to the FLEX 200, but I have not been able to contact the FLEX 200 after i started the converted config file. I have tried all the LAN ports (P4-P7), but there is no response. Do you have any suggestions?0
The primary reason for my wish to transfer the configuration is IP bindings and port routings. Perhaps it is better to just configure from new since transfer of configuration does not seem to be working.0
Hi Nireves,
usually, a new config is better, as you start with default config changes we applied during the past years.
Convert should also be doable, if you struggle, feel free to send us the config and we´ll help on that topic. https://support.zyxel.eu/hc/en-us/requests/new?ticket_form_id=114093996354
You can also create a new config file and copy/paste in notepad the part related to IP/Bindings and Port Routings, but this is may more complex as at least IP/Binding is on multiple parts in the config file (separated, in the interface, DHCP part).
Regards,
Tobias0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
