Zyxel VPN50 do now showing 1000MB/FULL
vkv
vkv Posts: 3 image  Freshman Member
edited August 2021 in Security
Hi!
model Zyxel VPN50
Router> show port status
Port    Status      TxPkts    RxPkts    Colli.    TxB/s     RxB/s     Up Time
1       Down        0         0         0         0         0         00:00:00
2       1000M/Full  3737264   8078234   0         10071     33471     00:52:17
3       1000M/Full  2433367   1336667   0         382       719       00:52:17
4       Down        477763    198993    0         0         0         00:00:00
5       1000M/Full  1516961   765206    0         33226     10769     00:52:17
6       Down        3607842   1526174   0         0         0         00:00:00
Router>
provider provides 500 Mbps
speed test showing
kv@dsm-ubuntu:~$ speedtest
   Speedtest by Ookla
     Server: Telecom Center - Moscow (id = 17091)
        ISP: Zao complat-telecom
    Latency:     0.74 ms   (0.30 ms jitter)
   Download:   417.82 Mbps (data used: 520.8 MB)
     Upload:   310.09 Mbps (data used: 139.3 MB)
Packet Loss: Not available.
kv@dsm-ubuntu:~$
BUT
direct connect to PC (without Zyxel) show more than 500+ Mbps
Question
Why Zyxel do not showing 500Mbps speed
Ths
  • gb5102
    gb5102 Posts: 25 image  Freshman Member
    A couple of suggestions:
    -BWM can add some overhead, you can likely increase performance by disabling BWM if you are not using it.
    -Content filter can also decrease performance, try to disable(if enabled) and see if there is any improvement.
    PeterUK Posts: 4,427 image  Guru Member
    The SPI firewall throughput of the VPN50 at 800Mbs does not mean TCP and so if you want to go faster you need bigger model.
  • vkv
    Which model do you recomend ?
    The VPN300 will do 1Gb TCP
