Configuration Management via SSH/SCP
tsch
tsch Posts: 9 image  Freshman Member
edited April 2021 in Security
Is there a way to copy files via SSH/SCP. We have a large amount of Zyxel USG's and want a Configuration Management, but so far only FTP works for me to transfer the Config. Are there other recommended ways to save the config of many Zyxel Firewalls? I tried via SCP but it seemed not be working. Thanks.
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    How about using python script to get configuration backup. just one click to download from device.
    It might reduce your maintenance effort.
    ~~~~~~~~~~~~~~~~~~~~cfg_download.py~~~~~~~~~~~~~~~~~
    from ftplib import FTP
    #Device info
    USG_IP = "192.168.2.1"
    ID = "admin"
    Password = "12345"
    Filename = 'startup-config.conf'
    #Log in to USG
    ftp = FTP(USG_IP)
    ftp.login(user=ID, passwd=Password)
    #Change folder and list
    ftp.cwd('/conf/')
    localfile = open(Filename, 'wb')
    ftp.retrbinary('RETR ' + Filename, localfile.write, 1024)
    #Connection close
    ftp.quit()
    localfile.close()
  • CHS
    CHS Posts: 181 image  Master Member
    Hi @lalaland
    Thanks for your sharing :)
