SecuExtender IPSec VPN Client licenses
CP98
After I activated the Zyxel VPN Client with a license key. Can I reuse the same key, for exemple, if I have to reinstall the Client on the same PC. What is one of the company PCs break, is the license key lost?
Hi @CP98The license key is bundled with your PC when you activate it the first time.If you would like to use the license key on a different PC, please provide us the license key or contact with our local representative/support or put your requirement in the community so that we can help you to reset your license status
.0 -
I need to reactivate secuextender ipsec vpn client0
Hi @Abbe
You may provide your license key of IPSec VPN Client to me by private message first, then I will further check if reactivate the key is acceptable.
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
