Broadcast VLANs from Switch via WLAN [No Internet - Please Help]
DrDrummer
DrDrummer Posts: 2 image  Freshman Member
Friend Collector
edited May 2024 in Wireless
Hi All,
I recently received NWA50AX Access Point and would like to use this to broadcast VLANs using multi-SSID. After setup, each SSID is showing up as an available network but when a device attempts to connect there is no internet.
I can connect through the router directly so I know I don't have any internet issues so I am obviously making a mistake in the setup between the switch and the AP.
Current settings as follows:
I have a TP Link TL-SG108E Easy Switch. VLAN are setup on that device using 802.1Q VLAN settings as follows:
VLAN 1 : Default_VLAN : Member Ports 1 - 8 (Untagged)
VLAN 2 : Work : Member Ports 1 - 4 (Untagged)
VLAN 3 : IoT : Member Ports 5 - 8 (Untagged)
The AP is plugged into Port 1 on the switch and in Nebula I have the following SSIDs setup with the following VLAN IDs.
SSID1: Home : VLAN 1
SSID2 : Work : VLAN 2
SSID3 : IoT : VLAN3
Each requires a unique WPA2 password.
Any help much appreciated!
    PeterUK Posts: 4,430 image  Guru Member
    edited February 2022
    Your VLAN setup just allows everything across the ports without a tagging.
    Do you have a VLAN router? As normally you give each VLAN a tag subnet between AP and router.
    The AP is set for VLAN 1 as native I would guess lets say to port 2 on the switch with port 1 to your router and I'm going to guess a normal home router with one subnet going by the info I have.
    Set VLAN 1 for ports 1 and 2 as untag and the rest for now forbidden Port PVID to 1 and ports to General mode.
    Have the AP set with
    SSID1: Home : VLAN 10
    SSID2 : Work : VLAN 20
    SSID3 : IoT : VLAN 30
    Set VLAN 10 with tag on port 2 and untag port 1
    Set VLAN 20 with tag on port 2 and untag port 1
    Set VLAN 30 with tag on port 2 and untag port 1
  • DrDrummer
    Friend Collector
    Thanks @PeterUK, your post has spurred some changes but I'm not quite there. The router is a Virgin Media Superhub 4 and I've swapped the switch for a new Netgear GS308E and setup the following:
    VLANs:
    10 (Ports 1,2,8)
    20 (Ports 3,4,8)
    30 (Ports 5,8)
    40 (Ports 6,8)
    99 (Ports 7,8)
    Port 8 is tagged throughout apart from in VLAN 99 where they're both untagged. PVIDs have been setup to correspond to the above.
    Port 8 is to the router. Port 7 is to the AP.
    I can't seem to do any VLAN assignments at the Virgin Hub so I'm curious whether that is a problem here?
    I found the setup I listed above don't work but really you need a router with VLAN and subnets.
    Try
    Set VLAN 1 for ports 1 and 2 as untag and the rest for now forbidden Port PVID to 1 on ports 1 and 2 and ports to General mode.
    on switch
    Set VLAN 10 with tag on port 2 and untag port 3 with port 3 PVID to 10 rest of the ports forbidden
    Set VLAN 20 with tag on port 2 and untag port 4 with port 4 PVID to 20 rest of the ports forbidden
    Set VLAN 30 with tag on port 2 and untag port 5 with port 5 PVID to 30 rest of the ports forbidden
    connect ports 1,3,4,and 5 to your router
    Just a note your not isolating your network as you don't have a VLAN router
  • Zyxel_Silvia
    Zyxel_Silvia Posts: 77 image  Zyxel Employee
    5 Answers Friend Collector
    Hi @DrDrummer ,
    For your application, your router need to have the capability to offer different subnet IP.
    we suggest you check your router setting and connect your computer to different port of router,
    and check if you can get different subnet IP.
    (ex.:
    connect to LAN port 1, get iP:192.168.1.x
    LAN port 2, ip:192.168.2.x
    LAN port 3, ip:192.168.3.x)
    If you all get the same subnet IP then we will suggest you only use VLAN1 to configure your switch and AP setting.
    if you can get different subnet IP, then you may refer @PeterUKs' suggestion.
    Thank you.
    Silvia
