[NEBULA] Switch client information
Hi ocean77
You can go to Switch -> Monitor ->Client to view the table of all the clients MAC addresses direct and indirectly connected to the switch ports.0 -
Hey @Nebula_Dean I've noticed that Switch > Monitor > Clients shows the devices connected to my non-administrable switch (that is connected to my NSW200) as its own clients. Shouldn't be better just to see those devices that are directly connected to it?"You will never walk along"0
@RUnglaube
It is true NSW will show the MAC of other clients from a different switch if your topology has another one connected to it. Basically what it does is it shows is the entries from the MAC table and records them.
However, to show only the devices are connected to it, you may have to use the authors way of seeing it through LLDP, I'll check if theres an enhancement in this function.1 -
Great! I'll be very attentive to check if you guys come up with an idea"You will never walk along"0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
