NWA55AXE Bridge + AP
MonsterD
MonsterD Posts: 3 image  Freshman Member
Third Anniversary
edited November 2023 in Nebula
Hello, we are using a nwa55axe as AP for our garden. As we need to bridge the lan to another building the idea was to get another nea55axe and use the bridge mode for this.
Question for me is if the bridge mode from one nwa55axe to the other will exclude to use it as AP in parallel?
regards
  • Zyxel_Silvia
    Zyxel_Silvia Posts: 77 image  Zyxel Employee
    5 Answers Friend Collector
    edited February 2022
    Hi @MonsterD ,
    Thank you for raising question here,
    our NWA55AX support smart mesh and wireless bridge.
    Please refer this post to configure your smart mesh and wireless bridge setting.
    https://community.zyxel.com/en/discussion/10160/nebula-how-to-extend-wireless-coverage-with-smart-mesh#latest
    Go to Help> Device function table can find more information.
    if you have further question, please feel free to reply us.
    Thank you.
    Silvia
  • MonsterD
    Third Anniversary
    thank your for your reply and the link to further information on howto setup the devices for a bridge mode.
    As mentioned there I enabled the Mash and bridge mode and after a reboot of the 2 NWA55AXE devices the AP overview shows the 2 connected APs (full green antenna and green outlined antenna).
    The bridge AP is now connected to a POE switch Zyxel 1900 with fix LAN-cable connected PC.
    The problem is now, that my connected PC on the far side does not get an IP via the bridge from the router.
    Please find below the setting I am looking for. (IP-Adresses from same range 192.168.0.xxx)
    please advice me on how to solve this.
    Thank you and regards
    Gernot
  • Zyxel_Silvia
    Hi @MonsterD ,
    we suggest the first step is to check the signal of wireless bridge,
    because your PC need to get the IP by pass through wireless bridge.
    second step,  we want to check your setting, may you enable zyxel support for us to visit.
    and you may tell us for organization/ site name through message.
    Thank you.
    Silvia
Nebula Tips & Tricks
