NWA50AX download speed progressively degrades
Hi @angelo5432 ,
Thank you for raising question here,
We will suggest you to exchange the cable and also try to connect to different port of router.
we also suggest to check the power supply, are two APs both running full power mode?
If the above information doesn’t help.
May you enable zyxel support for us to check?
you may tell us your organization /site name through messages.Silvia
If one works fine and the other isn't then I would think it could be a Ethernet issue.
What is your setup? How are they connected? How are your channels setup? Have you tried just swapping then two APs to rule out the AP itself?0 -
Hi @angelo5432 ,
Thank you Silvia and jpblanch75!
It was in fact the LAN cable. I used a different cable and now the download speed remains stable over time.
Great to hear!angelo5432 said:Thank you Silvia and jpblanch75!
It was in fact the LAN cable. I used a different cable and now the download speed remains stable over time.0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
