LTE3301-PLUS - asymmetric ping response times
Hi All,
I have a Zyxel LTE3301-PLUS router. I use mobile net (300Mb) and there is a wifi intranet containing some hosts and a printer.
The hosts can reach the internet with good speed via wifi. The problem occurs when I want to reach another host. The ping response time changes from 1ms to 1000ms and there is packet loss. The wifi network as intranet is not stable.
E.g. ping: host1 -> host2
$ ping 192.168.1.109 PING 192.168.1.109 (192.168.1.109) 56(84) bytes of data. 64 bytes from 192.168.1.109: icmp_seq=1 ttl=64 time=1046 ms 64 bytes from 192.168.1.109: icmp_seq=2 ttl=64 time=35.3 ms 64 bytes from 192.168.1.109: icmp_seq=3 ttl=64 time=528 ms 64 bytes from 192.168.1.109: icmp_seq=4 ttl=64 time=25.4 ms
And If I ssh into Zyxel router and ping back to the host the result is very bad:
ping: router -> host
From host to router it is fine:
ZySH> ping 192.168.1.2<br>common_ping: hostname 192.168.1.2<br>PING 192.168.1.2 (192.168.1.2): 56 data bytes<br>64 bytes from 192.168.1.2: seq=0 ttl=64 time=1.471 ms<br>64 bytes from 192.168.1.2: seq=1 ttl=64 time=112.857 ms<br>64 bytes from 192.168.1.2: seq=2 ttl=64 time=25.187 ms<br>64 bytes from 192.168.1.2: seq=3 ttl=64 time=45.170 ms
ping host -> router
$ping 192.168.1.1<br>PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.<br>64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=2.08 ms<br>64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=1.46 ms<br>64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=1.74 ms<br>64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=1.65 ms
Settings :
- RTS/CTS Threshold : 1500
- Fragmentation Threshold : 2000
- Beacon Interval : 100
- DTIM : 1
I have tried many things without result:
- 4 different computers
- Moving router to other places
- Changing band : 5G and 2.4G
- Changing RTS/CTS Threshold and Fragmentation Threshold
- Changing wifi channel (auto or some value)
- Changing Bandwidth (20, 20/40, 20/40/80)
Does anybody has some idea why it is happening?
Kind regards,
Gabor
fixing broken lines:
ping: router -> hostZySH> ping 192.168.1.2
ping host -> router$ping 192.168.1.1
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
