NWA210AX - Automatic SSH login from Openhab
Miky
Miky Posts: 11 image  Freshman Member
edited May 2024 in Wireless
i need autoconnect from Openhab to Zyxel AP, to turn on-off the wifi.
I'm able to turn on-off the wifi manually with a ssh connection from my Macbook.
But i'm not able from Openhab because i need to write it in a single command line like that:
ssh2 -p PASSWORD USER@ZYXEL_IP /configure terminal/wlan slot1/no activate
Someone more experienced than me can help me to find the correct line?
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @Miky
    Thanks for sharing the experience combining Openhab with Zyxel access point.
    To enable/disable wireless network at specific time, we have SSID schedule for users to setup.
    If the above functions do not meet your needs, could you share the applications that you’re going to implement?
    We’d like to advice if any features on AP could meet your work.
    Thank you
    Regards,
    Bella
  • Miky
    Hello Bella,
    thank you for your quick help!
    A time control is too rigid for my application, so I want to link the AP to openhab.
    I've now understood that the problem it`s probably because I'm running Openhab as a docker and maybe there's no pre-installed shell.
    Miky
  • zyman2008
    zyman2008 Posts: 242 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    edited March 2022
    Hi @Miky,
    Try this command,
    echo -e "configure terminal\nwlan slot1\nno activate\nexit\nexit\nexit" | sshpass -p yourpassword ssh admin@192.168.1.1
