How to configure Vlan Trunk - Gs1910
KleinStreisend
KleinStreisend Posts: 6 image  Freshman Member
Friend Collector
edited August 2022 in Switch
Good afternoon, could you tell me how to configure the trunk port for vlan on the zyxel gs1910 switch. I have 2 vlans 100 and 200.
It is necessary to connect 2 switches so that vlan traffic passes between them.
Also, these ports are aggregated via LACP. Actually, I need to make them a trunk port.
On cisco, this is done through the "switchport mode trunk" command.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,633 image  Zyxel Employee
    edited February 2022 Answer ✓
    Hi @KleinStreisend,
    Welcome to Zyxel community!
    Looks like you want lacp ports could transmit VLAN 100 & 200, right?
    If yes, you just need to set "1,100,200" in Allowed VLANs on lacp ports.
    Hope it Helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @KleinStreisend,
    Hope it Helps.
    Zyxel Melen
  • KleinStreisend
    Friend Collector
    edited March 2022
    @Zyxel_Melen
    thank you very much, yes it is working perfectly.
    On the cisco side work with -
    switchport nonegotiate
