Why does the apt100 will not send the configuration file?
Hi @IAE_123,
Greeting Forum,
Could you kindly perform the following and send the result to us?
1)Check there is correct setting in System->Notification->Mail Server
2)Capture the Packet when the schedule arrives
Kevin
Tested here on VPN300 for Configuration File Backup with Daily 1 hour so every send at 1am every day to my local Email server with send Email checked works fine.
Edit: it looks like the config is sent when their are changes made
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
