Why does the apt100 will not send the configuration file?
IAE_123
IAE_123 Posts: 1 image  Freshman Member
Second Anniversary
Bevor the atp100 will send the configuration file to a e-Mail adress.
Since two weeks it is not sending.
The daily report file is sending correctly.
Where i must config that the apt100 send the configuration File?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @IAE_123,
    Greeting Forum,
    Could you kindly perform the following and send the result to us?
    1)Check there is correct setting in System->Notification->Mail Server
    2)Capture the Packet when the schedule arrives
    Kevin
    PeterUK Posts: 4,415 image  Guru Member
    edited February 2022
    Tested here on VPN300 for Configuration File Backup with Daily 1 hour so every send at 1am every day to my local Email server with send Email checked works fine.
    Edit: it looks like the config is sent when their are changes made
  • zyman2008
    zyman2008 Posts: 242 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    Hi @IAE_123,
    If there no configuration change compare with previous one.
    Then it'll not send out the same backup.
