NWA210AX - Automatic SSH login from Openhab
i need autoconnect from Openhab to Zyxel AP, to turn on-off the wifi.
I'm able to turn on-off the wifi manually with a ssh connection from my Macbook.
But i'm not able from Openhab because i need to write it in a single command line like that:
ssh2 -p PASSWORD USER@ZYXEL_IP /configure terminal/wlan slot1/no activate
Someone more experienced than me can help me to find the correct line?
Hi @Miky
Thanks for sharing the experience combining Openhab with Zyxel access point.
To enable/disable wireless network at specific time, we have SSID schedule for users to setup.
If the above functions do not meet your needs, could you share the applications that you’re going to implement?
We’d like to advice if any features on AP could meet your work.
Thank you
Regards,
Bella
Hello Bella,thank you for your quick help!A time control is too rigid for my application, so I want to link the AP to openhab.I've now understood that the problem it`s probably because I'm running Openhab as a docker and maybe there's no pre-installed shell.
Miky0
- 602 USG FLEX H Series
- 480 News and Release
