5G connection disconnected in VMG3625-T50B model
kuroshebayat
in Home Router
Hi, I have a home g5 modem that loses its 5G connection every few minutes and is not displayed in the WiFi list. What is the problem?
Hello @kuroshebayat
Are you able to share a bit more of a diagram of how your devices are connected together please?
e.g. is it
Internet<- home 5g modem<-VMG3625-T50B
or is it
Internet <- VMG3625-T50B<- home 5g modem
It could help us to help you further.
Kind regards,
Tony0 -
tonygibbs16 said:Hello @kuroshebayat
e.g. is it
or is it
Kind regards,
Tony
I have the same problem. My setup is simple I have no GSM backup just a simple ADSL over the phone outlet.
I have enabled both 2.4G and 5G bands. While 2.4G works without any interruption for no reason 5G drops and disappears from the WiFi list. After couple of minutes comes back again.
My Current Firmware Version is V5.50(ABPM.5)F1 and Current WWAN Package Version is 1.20.
This problem causes me a lot troubles, I need urgently get it fixed.
Thanks in advance.0 -
Hello @RealBlue
I cannot find the firmware, so I suggest that you log a ticket please at https://www.zyxel.com/form/contact_support.shtml?modelName=VMG3625-T50B&modelDesc=Dual-Band%20Wireless%20AC/N%20VDSL2%20Gigabit%20Gateway&productModel=VMG3625-T50B to get an answer.
Kind regards,
Tony0 -
it seems like a common issue in zyxel products.I have the same problem here1
Internet <- VMG3625-T50B<- home 5g modemtonygibbs16 said:Hello @kuroshebayat
e.g. is it
or is it
Kind regards,
Tony
Hello @kuroshebayat
Thanks for your reply.
If you need an urgent solution to this, then you could do what I have done with my Zyxel VMG1312-B10D that only support 2.4GHz Wifi, which is to put a WiFi range extender in front of it that does both 2.4GHz and 5GHz WiFi.
I don't know much about the Zyxel WiFi range extenders.
I have personally been using a TP-Link RE300 dual band WiFi range extender see https://www.tp-link.com/uk/home-networking/range-extender/re300/ for over 12 months and it has been working really well for me.
- It range extends the 2.4GHz WiFi coverage of my Zyxel router, and it also provides 5GHz band connectivity where I did not have it before.
- I have found it very stable and have had 2 firmware updates on it from TP-Link in the past 12 months.
I hope that this is helpful.
Kind regards,
Tony
- 441 Beta Program
- 294 Service & License
- 461 News and Release
